bjussab
Jul 30, 2015Aspirant
ReadyNAS Duo RND2120 v2 (v1) - stuck on system starting up RAIDar
Hello everyone. Hope someone can share some ideas and help me. I bought a ReadyNAS Duo in 2010/2011. I used it for a couple of years before it was left to sit on a shelf unused. I recently st...
bjussab
Oh didn't know that. Deleted the partition and inserted into the Duo. Saying syncing volume c now. Hope it goes well.
Yes, x-raid is what want and set it to when the message was shown.
Thanks
Thanks
Jul 30, 2015Guru - Experienced User
Deleting partitions is safe, that restores the drive to an unformatted state. Creating new partitions/reformatting might result in seeing a corrupt root message (more likely if you insert drives with the NAS powered down).
But since you are seeing the sync starting, the NAS is responding normally.
