billm11
Jan 07, 2013Aspirant
ReadyNAS DUO "Setup" Greyed Out
I've been using a ReadyNasDuo (v1) without issue for a couple of years. I've started having some very unusual and unexplained problems; - Started by shares not being available on the network - No ...
Jan 07, 2013Guru - Experienced User
OS reinstall can be done from the duo front panel (http://www.readynas.com/kb/faq/boot/how ... _boot_menu) Note you have a duo v1, so you need to scroll down to the "Duo / NV / NV+ / X6/600" section. You need to be careful not to do a factory default by mistake (which would wipe your data).
billm11 wrote: Thanks for your reply, but I'm not sure what you mean? OS on the ReadyNas? I'm assuming this is what you mean as I get the same error on different machines.
I'm (a) not sure how to do this and (b) not sure how I get access to the ReadyNAS to do it.
I've discovered if I hit the IP address of the NAS I can access the Shares directory (it sees none, there should be two) but nothing else
An OS reinstall will reset your admin password to netgear1, and will also reset the IP configuration to the default DHCP. Other settings and data should be preserved.
