Nov-Ange-Lion
Jan 29, 2023Follower
Orbi setup shows "No intertet connection"
Dear Netgear communities
I just bought my first Orbi unit today and having difficulties with internet connection. I basically followed all instructions on the App, and when I gets to the last step for "Checking Internet Connection" it keeps failing.
Here is my devices and setup:
Router: Orbi RBk352
Modem: Nighthawk AC1900
I have been using the Nighthawk for 5 years and it works fine. Not sure is because the connection/ setup on Nighthawk is wrong.
I just use ethernet cable to connect Orbi and Nighthawk, and I am still able to use internet with the Nighthawk at the moment. Shall I change the Nighthawk into modem only function first?
Your AC1900 modem? Put it in modem only modem. Not modem/router mode.
otherwise you're in a double nat.
Or you can put the orbi in access point mode (can only be done through the browser, not the app).
A double nat happens when you cascade more than 1 router.
https://kb.netgear.com/30186/What-is-Double-NAT
https://kb.netgear.com/30186/What-is-Double-NAT - michaelkenwardGuru - Experienced User
Which one?
AC1900 is not a reliable guide to model number. Many devices come with an AC tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe Wi-Fi speeds.
Look at the label on the device for the model number.
- KevinLiTNETGEAR Moderator
Hello Nov-Ange-Lion,
Welcome to the NETGEAR Community!
I understand that you are having issues with the initial setup of your new RBR352.
Please navigate to the link below for a video to assist you with your initial Orbi Mesh System setup:
How to Set Up Orbi With the Orbi App | NETGEAR - Bing video
Best,
Kevin
Community Team
