shortskoolbus
Nov 07, 2013Aspirant
ReadyNAS DUO speeds are horribly slow...
I've kind of lived with it for a couple of years now. I've done all of the performance tweaks suggested from the sticky in this section... but here's what i'm saying. I copy a 2 GB file over from a...
Nov 08, 2013Guru - Experienced User
The write speed looks good, so you probably don't need the direct connect. For future reference, that is connecting the PC directly to the NAS with no switch. You need to set a temporary static IP address on the PC to use that mode.
I would start be retesting write speed with jumbo frames off.
