shortskoolbus
Nov 07, 2013Aspirant
ReadyNAS DUO speeds are horribly slow...
I've kind of lived with it for a couple of years now. I've done all of the performance tweaks suggested from the sticky in this section... but here's what i'm saying. I copy a 2 GB file over from a...
Nov 15, 2013Guru - Experienced User
Sorry, I meant read speed.
shortskoolbus wrote: Do you mean the write speed of 3.8 MB/s? Or was it supposed to be the read speed?
Either it means that a router or switch between the PC and the NAS doesn't support jumbo frames, or that the PC happens to run slower when you use them. You can try to play with NIC card settings, or just leave them off.
shortskoolbus wrote: Speeds are about twice as fast with Jumbo Frames off... What does this indicate?
Maybe try this test tool? http://www.808.dk/?code-csharp-nas-performance
You'll need to map a drive letter to use it.
Also, have you tried testing to/from the internal drive of the PC?
