xrix
Sep 27, 2025Aspirant
ReadyNas Duo stuck on "system starting up"
I desperately need some help. I bought a used ReadyNAS Duo today. After struggling with the password, I eventually got in, but I couldn’t do much besides changing the password. I wasn’t able to uploa...
Sep 27, 2025Guru - Experienced User
xrix wrote:I bought a used ReadyNAS Duo today.
Now, when I start up the NAS, it just says “System starting up” and has been stuck like this for a long time.
Let's start by confirming the model. ReadNAS 2-bay system models were
- Duo
- Duo v2
- Ultra 2
- Pro 2
- RN102
- RN202
- RN212
- RN312
- RN422
These are quite different, so we need to identify what you have.
It sounds like your system has an LCD screen - is that the case? If so, you must have an RN422, as that is the only one that had such a screen.
If (not) or if you just want to confirm the model, then you can download RAIDar 6.5 from
- https://kb.netgear.com/20684/ReadyNAS-Downloads#raidar
If you need Java, you can download it from
Note that RAIDar won't work on Macs with M-series processors.
xrix
its a Duo, it says it in the Raidar app, like i said..
