bedlam1
Jan 16, 2017Prodigy
Raidar V6.2 erroneously reporting Status as "System starting up"
As stated in the title Raidar appears stuck on Status "System starting up" but my Readynas is running perfectly
Any clues on this anyone?
Pro 4 running OS V6.6.1
- mdgm-ntgrNETGEAR Employee Retired
Can you download the logs and send those in (see the Sending Logs link in my sig)?
- bedlam1Prodigy
Sent........
- UtilaFoundationAspirant
Same issue. RAIDAR reports sytem starting yet system has started and works fine. No login button within RAIDAR. Box has worked fine since 15DEC16. Yesterday, RAIDAR errors ocurred.
- jtowntexGuide
I believed you might have fixed the issue because RAIDar was now showing "Remote Support" instead of "Starting Up." When I turned off remote support it went back to "Starting Up." I have now re-enabled "Remote Support" and RAIDar once again lists the status as "Remote Support." I have no idea how useful that information might be but there it is. I will let that other conversation die since basic access is no longer an issue for me.
- bedlam1Prodigy
I don't know why but Raidar now reporting Status as "Healthy"
