bedlam1
Jan 16, 2017Prodigy
Raidar V6.2 erroneously reporting Status as "System starting up"
As stated in the title Raidar appears stuck on Status "System starting up" but my Readynas is running perfectly Any clues on this anyone? Pro 4 running OS V6.6.1
mdgm-ntgr
Jan 16, 2017NETGEAR Employee Retired
Can you download the logs and send those in (see the Sending Logs link in my sig)?
- bedlam1Jan 16, 2017Prodigy
Sent........
- UtilaFoundationJan 16, 2017Aspirant
Same issue. RAIDAR reports sytem starting yet system has started and works fine. No login button within RAIDAR. Box has worked fine since 15DEC16. Yesterday, RAIDAR errors ocurred.
- jtowntexJan 16, 2017Guide
I believed you might have fixed the issue because RAIDar was now showing "Remote Support" instead of "Starting Up." When I turned off remote support it went back to "Starting Up." I have now re-enabled "Remote Support" and RAIDar once again lists the status as "Remote Support." I have no idea how useful that information might be but there it is. I will let that other conversation die since basic access is no longer an issue for me.
