AndreasSchmid
Jan 03, 2017Aspirant
ReadyNAS DUO unzulässiges Herunterfahren
Ein unzulässiges Herunterfahren wurde festgestellt. Zur Gewährleistung der Datenintegrität sollte eine Dateisystemprüfung durch einen Neustart des NAS über FrontView durchgeführt werden. Dabei muss d...
Jan 03, 2017Guru - Experienced User
You might have lost power for a moment or two. Perhaps check the connections on both the power brick and the back of the duo.
@Google Translate wrote:
Vielleicht haben Sie die Macht für einen Moment oder zwei verloren. Vielleicht überprüfen Sie die Anschlüsse auf dem Power Brick und die Rückseite des Duos.
- AndreasSchmidJan 03, 2017Aspirant
Hello StephenB
Thanks a lot for your quick answer. The case that you wrote about can not be true, because 1st) The NAS is supported by a UPS device and 2nd) The second Ready NAS (same Type, same Capacity, same SW) didn't have these unaccetable shutdown.
Did you have any other idea? At the moment in in process to replace my two ReadyNAS.
- StephenBJan 03, 2017Guru - Experienced User
AndreasSchmid wrote:
Hello StephenB
The log says that there was an unexpected shutdown.
I was thinking that perhaps the power connections were loose - in which case the UPS protection wouldn't help.
Another possibility is that the NAS software simply crashed for some reason. I'm not sure if it would automatically start if that happens or not. But you think that is possible, you could try a factory reset (reconfiguring everything, and restoring the data from backup).
- SlasJan 06, 2017NETGEAR Employee Retired
Hallo AndreasSchmid,
wie ist der Readynas Status jetzt?
Hast Du dich entschieden das NAS System neuaufzusetzen?
Grüße
Slas
NETGEAR Community Team
