Rocketrobo99
Oct 17, 2011Aspirant
ReadyNAS-Duo Upgrade fail
Readynas Duo Upgrade – FAIL I have a new (Sept 2011) ReadyNas Duo. The hookup and config went exactly according to instructions, with some much appreciated help from this forum. I went with the mor...
Oct 18, 2011Guru - Experienced User
I have done much larger directory copies with my unmodified Duo without seeing the copy failures you are seeing - the largest share being about a terrabyte. The copies were done on wired gigabit ethernet connections, usually using robocopy. Some went NAS to NAS, most were between the NAS and the PC.
I suspect your bulk copy problem is network related - have you checked the duo network stats?
