kennethmacleod
Jul 10, 2010Aspirant
ReadyNas Duo USB Share - Write-Protected
Hi All, I am looking for some help. I have a Netgear ReadyNas NV+ running perfectly. I also have a Netgear ReadyNas Duo running perfectly. I have a Western Digital 2TB USB drive which I have plugge...
kennethmacleod
Jul 11, 2010Aspirant
Hi,
Many thanks for posting it as I may not have accidentally stumbled upon that last night. My HD does not have any way to control power management either. I will check mime out tonight and see if it is when the drive goes into power saving that the write protected issue begins. I will keep you posted.
