Retroperra
Jan 05, 2015Aspirant
ReadyNAS Duo V1 - does not boot [SOLVED]
Hi all! Please stay with my rather long description - I know it's a bit long; In short, my Duo started to act up. It didn't start first, so after some pondering I realised that by taking out di...
Jan 05, 2015Guru - Experienced User
Linux Reader works on disk 1 (http://www.diskinternals.com/linux-reader/). Disk 2 (the "parity disk") doesn't actually have a data partition (though the data is there), so you can't easily extract its data.
