Retroperra
Jan 05, 2015Aspirant
ReadyNAS Duo V1 - does not boot [SOLVED]
Hi all! Please stay with my rather long description - I know it's a bit long; In short, my Duo started to act up. It didn't start first, so after some pondering I realised that by taking out di...
Retroperra
Jan 07, 2015Aspirant
The Linux Reader worked great!
I belive I understand a bit more on how the filesystem works in the DUO. The third partition on disc one holds 'links' to physical files living in the RAW partitions on disc one and two.
It takes some time though to find the folders, rescue to and then move to where they can be used.
Not all files did existed, sadly, so they could be extracted from the DUO-disc but a while lot more is saved than earlier.
I'm much happier now ;)
