t0ny84
Apr 23, 2021Aspirant
ReadyNAS Duo V1 - Help Needed - Remote\Cloud Access & Applications
Hi all, I Am Hoping (praying) someone can help me. I recently purchased what I thought was a second hand ReadyNAS DUO V2 (upgradable to newer 6.5 firmware) unit off eBay. My assumptions we're bas...
- Apr 23, 2021
One limitation is that this NAS can't handle disks > 2 TB.
t0ny84 wrote:
1) Now that v1 is end of life where can I download copies of the applications for this unit?
Current (and final) firmware is here: https://kb.netgear.com/000038792/RAIDiator-Version-4-1-16-Sparc Though check-for-updates will likely work. Documentation is here: https://www.netgear.com/support/product/RND2000v1_(ReadyNAS_Duo_v1).aspx
https://kb.netgear.com/24546/Add-ons-for-RAIDiator-4-1-3-Sparc
Plus some that have a small cost here: https://rnxtras.com/readynas-os4-sparc
These aren't fast and have limited memory, so don't overdo the add-ons.
Also, the last firmware update was a few years back, and no security patches have been applied since them. Personally I don't recommend exposing this NAS to the internet.
t0ny84 wrote:
2) How can I setup remote\cloud Access to this unit?
ReadyCloud only is available for OS-6 NAS (not 4.1). Getting a router with OpenVPN is the safest way to get remote access.
t0ny84 wrote:
3) Is there any custom firmware\applications available?
If you meant add-ons, then I answered that in #1.
Apr 23, 2021Guru - Experienced User
mdgm
Apr 23, 2021Virtuoso
Note that the Duo v1 (runs 4.1.x) and Duo v2 (runs 5.3.x) are both EOL. Neither of those runs OS6.
