t0ny84
Apr 23, 2021Aspirant
ReadyNAS Duo V1 - Help Needed - Remote\Cloud Access & Applications
Hi all, I Am Hoping (praying) someone can help me. I recently purchased what I thought was a second hand ReadyNAS DUO V2 (upgradable to newer 6.5 firmware) unit off eBay. My assumptions we're bas...
- Apr 23, 2021
One limitation is that this NAS can't handle disks > 2 TB.
t0ny84 wrote:
1) Now that v1 is end of life where can I download copies of the applications for this unit?
Current (and final) firmware is here: https://kb.netgear.com/000038792/RAIDiator-Version-4-1-16-Sparc Though check-for-updates will likely work. Documentation is here: https://www.netgear.com/support/product/RND2000v1_(ReadyNAS_Duo_v1).aspx
https://kb.netgear.com/24546/Add-ons-for-RAIDiator-4-1-3-Sparc
Plus some that have a small cost here: https://rnxtras.com/readynas-os4-sparc
These aren't fast and have limited memory, so don't overdo the add-ons.
Also, the last firmware update was a few years back, and no security patches have been applied since them. Personally I don't recommend exposing this NAS to the internet.
t0ny84 wrote:
2) How can I setup remote\cloud Access to this unit?
ReadyCloud only is available for OS-6 NAS (not 4.1). Getting a router with OpenVPN is the safest way to get remote access.
t0ny84 wrote:
3) Is there any custom firmware\applications available?
If you meant add-ons, then I answered that in #1.
t0ny84
Apr 24, 2021Aspirant
Thanks for your assistance, will check these out.
When I entered the serial into Netgear's Website it gives me:
ReadyNASRND2000
RND2000v2 (ReadyNAS Duo v2) – Diskless
Model / Version: RND2000 v2
On the information page it shows Radiator 5.3.13 which I tried to upgrade to (when this failed I went searching for information and found even though it's named a v2 it is infact a v1)
Thanks so much again :)
t0ny84
Sandshark
Apr 24, 2021Sensei
Then it is a V2, and that's the last OS available for it. Neither a Duo V1 nor V2 is upgradable to OS6. Only Intel based legacy NAS (and then excluding a couple that have a 32-bit processor) can be upgraded. What you wanted was an Ultra2, UIltra2Plus, Pro2, or a unit that runs OS6 natively. If you do go lookiong for another, I recommend you avoid the 100 series. They are extremely limited memory wise and there are already OS functions that have had to be disabled on them.
Your best option for either Duo model is a router that supports OpenVPN, as StephenB suggested. The remote access capability that they once offered has been taken down for a number of years.
If you want a real project, there is this for updating the unit to a newer (but also no longer current) generic Debian OS: http://natisbad.org/NAS/index.html.
