Tigryss
Dec 14, 2015Aspirant
ReadyNAS duo v1 after update to 4.1.14 very slow
Hi I use my ReadyNAS duo v1(RND2000/1100 v1?) almost 7 years, and working fine after 4.1.14 update, i got a problem with network speed. I got max 700-720 kb/s. I made already factory reset, p...
BrianL2
Dec 14, 2015NETGEAR Employee Retired
Hi Tigryss,
Welcome to the community!
Try to do a direct connection between your ReadyNAS DUO and your PC. Then test copying some files to know if the transfer speed improves or stays the same.
Kind regards,
BrianL
NETGEAR Community Team
Tigryss
Dec 16, 2015Aspirant
can the nas handle with pc to pc connection or sould i take a cross cable?
- StephenBDec 16, 2015Guru - Experienced User
No need for a crossover, the NAS nic auto-senses.
- TigryssDec 19, 2015Aspirant
Hi Stephen,
so if I connect direct to other pc then the peed
is between 670-1100k/s if i count that 1 Gb takes 15-20 min
but it's shows 7 second step on the screen. it's realy annoying
1s 13,9 Mb/s
2s 7,0 Mb/s
3s 4,6 Mb/s
4s 3,5 Mb/s
5s 2,8 Mb/s
6s 2,0 Mb/s
7s stalled
back to 1s ....
Ohh and i got a ReadyNas Ultra 2 with the same issue there is 1100-1200kb/s the speed from the same pc. But if I do copy from other linux server to the same pc then over 15000 k/s
