Tigryss
Dec 14, 2015Aspirant
ReadyNAS duo v1 after update to 4.1.14 very slow
Hi I use my ReadyNAS duo v1(RND2000/1100 v1?) almost 7 years, and working fine after 4.1.14 update, i got a problem with network speed. I got max 700-720 kb/s. I made already factory reset, p...
Tigryss
Dec 16, 2015Aspirant
can the nas handle with pc to pc connection or sould i take a cross cable?
Dec 16, 2015Guru - Experienced User
No need for a crossover, the NAS nic auto-senses.
- TigryssDec 19, 2015Aspirant
Hi Stephen,
so if I connect direct to other pc then the peed
is between 670-1100k/s if i count that 1 Gb takes 15-20 min
but it's shows 7 second step on the screen. it's realy annoying
1s 13,9 Mb/s
2s 7,0 Mb/s
3s 4,6 Mb/s
4s 3,5 Mb/s
5s 2,8 Mb/s
6s 2,0 Mb/s
7s stalled
back to 1s ....
Ohh and i got a ReadyNas Ultra 2 with the same issue there is 1100-1200kb/s the speed from the same pc. But if I do copy from other linux server to the same pc then over 15000 k/s
- StephenBDec 19, 2015Guru - Experienced User
If you look at the network stats on the NAS screen (network->interfaces, "show errors") are you seeing errors increasing during the transfer?
