Tigryss
Dec 14, 2015Aspirant
ReadyNAS duo v1 after update to 4.1.14 very slow
Hi I use my ReadyNAS duo v1(RND2000/1100 v1?) almost 7 years, and working fine after 4.1.14 update, i got a problem with network speed. I got max 700-720 kb/s. I made already factory reset, p...
Tigryss
Dec 28, 2015Aspirant
On the windows PC was jumbopkg enabled and flow control was on disabled and not auto-n...
NAS performance tester 1.7 http://www.808.dk/?nastester
Running warmup...
Running a 1000MB file write on \\\backup 5 times...
Iteration 1: 10,79 MB/sec
Iteration 2: 10,89 MB/sec
Iteration 3: 10,66 MB/sec
Iteration 4: 11,05 MB/sec
Iteration 5: 10,88 MB/sec
Average (W): 10,85 MB/sec
Running a 1000MB file read on \\\backup 5 times...
Iteration 1: 11,60 MB/sec
Iteration 2: 11,56 MB/sec
Iteration 3: 11,45 MB/sec
Iteration 4: 11,50 MB/sec
Iteration 5: 11,58 MB/sec
Average (R): 11,54 MB/sec
but if i try over sftp / ssh then I got only 870 -950 kb/s is there any filter option?
Dec 28, 2015Guru - Experienced User
Jumbo frames certainly shouldn't be enabled on fast ethernet, and generally turning flow control on is a good idea.
Why do you need sftp on your local network?
I've never used sftp with the NAS, though I have used ftps for over-the-internet transfers. Speeds are definitely slower than SMB.
- TigryssDec 28, 2015Aspirant
sftp because I'm lasy. :D I installed after factory reset only the ssh and nothing else until I don't have a right speed. :)
- StephenBDec 29, 2015Guru - Experienced User
If you're getting 11 MB/s with SMB/CIFS/NFS, then the network setup is fine.
Lower speeds with rsync and ftp (all flavors) are expected. I suspect FTP speeds could be improved (they might even be throttled in the .conf). Not sure about sftp.
- TigryssDec 29, 2015Aspirant
yes It seams to work 300gb in 5,7 h thanks for helping. :D
