VelocityKendal
Dec 03, 2015Aspirant
ReadyNas Duo v1 keeps locking up (inaccessible)
Hello everyone, My ReadyNas Duo has been running faultlessly for years then suddenly I noticed is was offline in my LAN and I couldn't access Frontview in a browser. The device seemed to have fro...
Dec 03, 2015Guru - Experienced User
Your OS partition looks ok.
Have you gotten the data off the NAS?
- VelocityKendalDec 03, 2015Aspirant
StephenB wrote:Your OS partition looks ok.
No not yet, I don't currently have any means to move the data anywhere. For the relatively brief periods of time I can get it up and running I can browse the shares on the network as normal. i was kind of hoping to address the cause of it falling over without having to move the data off the disks.
- JennCDec 03, 2015NETGEAR Employee Retired
Hello VelocityKendal,
Welcome to the community!
It is best you back up the data asap. Then download logs from the FrontView once you get access to it again.
- StephenBDec 03, 2015Guru - Experienced User
If you are using the default xraid, Linux Reader ( http://www.diskinternals.com/linux-reader/ ) can read the files on the data drive (which is usually drive 1). It runs on a windows PC, and you need to connect the drive using SATA or a USB adapter of some sort.
I agree with JennC that you should extract the data off first.
