VelocityKendal
Dec 03, 2015Aspirant
ReadyNas Duo v1 keeps locking up (inaccessible)
Hello everyone, My ReadyNas Duo has been running faultlessly for years then suddenly I noticed is was offline in my LAN and I couldn't access Frontview in a browser. The device seemed to have fro...
VelocityKendal
StephenB wrote:Your OS partition looks ok.
Have you gotten the data off the NAS?
No not yet, I don't currently have any means to move the data anywhere. For the relatively brief periods of time I can get it up and running I can browse the shares on the network as normal. i was kind of hoping to address the cause of it falling over without having to move the data off the disks.
JennC
Dec 03, 2015NETGEAR Employee Retired
Hello VelocityKendal,
Welcome to the community!
It is best you back up the data asap. Then download logs from the FrontView once you get access to it again.
- StephenBDec 03, 2015Guru - Experienced User
If you are using the default xraid, Linux Reader ( http://www.diskinternals.com/linux-reader/ ) can read the files on the data drive (which is usually drive 1). It runs on a windows PC, and you need to connect the drive using SATA or a USB adapter of some sort.
I agree with JennC that you should extract the data off first.
- VelocityKendalDec 04, 2015Aspirant
Well I tried to download the logs and in doing so it seems to have crashed Frontview, I can't connect to the page at all any more. I still have SSH access however, is there a way I can download the logs via that?
- JennCDec 04, 2015NETGEAR Employee Retired
It seems you may really need to contact support so they can check on this and have a higher level check on your NAS remotely.
However, since your NAS is a legacy unit that must no longer have support warranty, you can avail their per incident support.
