vitk
Jul 28, 2017Follower
Readynas duo v1 migration
Hello, The NIC in my old Readynas duo v1 w 2x2TB disks gone bad. I got another Readynas duo v1 device, that came with one 2tb disk in it. I need to make the new Duo work with thedisks from my old o...
- Jul 28, 2017
First manually install the same firmware on the replacement NAS as you are running in the original. If you don't know the firmware, then just install the latest firmware on the replacement (currently 4.1.16).
Then power down the replacement, remove the disk drive. Then insert the two disk drives form the old NAS (keeping them in the same slots).
After that, just power it up.
Jul 28, 2017Guru - Experienced User
