M_J's avatar
M_J
Readynas DUO (V1) Network speed over gigabit network running at 10Mbit (help!)
Hi, I've been searching on and off for over a week for a solution to this problem.
My DOU v1 (old but still serving the purpose) is connected to a trust gigabit switch.  It has a 1TB seagate drive and a 2Tb seagate (running as a 1 obviously)  The 1TB is listed on the original approved hardware list.
Until recently this setup was working brilliantly.  I was able to transfer files, usualy via ftp at over 20Mb/s confirming that a gigbit connection was working.  Now, I'm lucky to get 1.2 MB/s, sometimes 1.4 or 1.5.  I generally get 800 KBit/s or so.
I've changed the CAT 6 cable for another CAT 5e with no joy.  I've connected 2 laptops with the same cables to the switch and transferred large files at 100's MB/s confirming the switch is "fine".  Frontview reports a gigabit full duplex connection with jumbo frames enabled and the default MTU.
I've connected the DUO directly to one of the laptops and seen exactly the same speed issue.  So all in all it seems the NAS itself is the problem.  I've even removed the 2Tb drive and run it using the approved drive only, and seen no change.
I'm out of ideas and worried it's the DUO network port itself thats the problem.  Everything else seems fine, so if anyone can offer some suggestions I'd appreciate it.  I've scoured google and the forums and read plenty about MTU values and cables and tested everything I can.  Lastly, the error logs show 0 errors for everything but the TCP Retransmits.  Which is very high (I havn't got access to the real value right now) so I'm guessing that points to the real error - but I have no idea what, with limited knowledge of networking.  Perhaps that's enough for someone with the know-how to say "it's obvious, that means...etc etc" !
Many thanks
Mike
  • StephenB's avatar
    What firmware are you running?
    It's possible that the duo's ethernet NIC is simply failing.  Hopefully not.
    Were you always using jumbo frames?  Also is the speed issue in both directions, or only one?
    Also, failing disks will also kill performance, so you should look at the disk health for the drives.
    Though you've likely already tried this...  Reboot the duo if you haven't already done that.
    • M_J's avatar
      M_J
      Thanks for a swift reply!
      I'm running Radiator 4.1.15 ( I was on 4.1.13, noticed the slow down and then updated a few days ago).
      I started using jumbo frames when I first plugged into the gigabit switch, around 18 months ago. Which seemed to work very well indeed.  The speed issue affects both directions, although tranferring from NAS to PC is slightly quicker, around 1.2 Mbytes/s vs 850Kb/s from PC to NAS, in the test I just performed using a 29.6 Mb mov file.  This is over FTP again by the way.  Via ethernet, over the switch.
      I've been restarting the DUO almost every time I start testing theories, and I just started it now to do the test above.  The network logs showed 0 errors before the test and after the test I can now see :
      TCP Retransmits 7
      Unrecovered TCP Retransmits 4
      - besides that, all seems perfectly well.
      Checking the disk health in the SMART+ window shows 0 errors for both drives.  I'd feel better if I did actually see some errors I think!  Perhaps there's a more effective way I can diagnose disk health?  Or indeed the network port health.
      Thanks again,
      Mike
ProSupport for Business
