bryn_hird
Aug 11, 2016Aspirant
ReadyNAS Duo v1 not completely booting up after replacing failed disk
Background
I have a ReadyNAS Duo V1 with a failing disk. System emails indicated :
Disk 2 did not pass SMART self-assessment test. Please replace this disk as soon as possible.
Growing SMA...
- Sep 12, 2016
Finally done more detailed tests on the second disk I acquired and find faults. The cause seems to be a faulty disk. I have done a factory reset with the first 2TB disk I purchased and it's working fine, and faster than before, but obviously not in a RAID configuration.
Clearly I was too patien. My investment in testing tools will be put to good use whenever I buy new hard drives.
Many thanks to all contributors.
mdgm-ntgr
Aug 11, 2016NETGEAR Employee Retired
Why are you still running a beta firmware release?
RAIDiator 4.1.14 was released back in October 2014 which is getting close to two years ago now. RAIDiator 4.1.15 was just released recently.
Is your data backed up?
If you can login to https://ip.address.of.nas/admin you should be able to see the state of the sync and download the logs.
bryn_hird
Thanks for the quick response.
No reason for using beta, I thought I was on latest when I kicked this process off, but clearly not. Unless this situation does not resolve itself I shall wait until the sync completes before updating. If you have knowledge there was a related bug in the beta release, corrected for the final release, I shall reconsider.
I do not have a backup. I accept it is a terrible lapse and I am in the process of correcting (such as acquiring a back up device) but since I know I can access my data if this fails, I consider the risk of data loss low.
I am unable to log onto the admin account using https://ip.address.of.nas/admin. I've used several devices to attempt to log in. The device has not been moved nor the network reconfigured since I was last able to log on.
