clblackman
Nov 21, 2015Aspirant
ReadyNAS Duo v1 OS Reinstall questions
From my previous post: I have purchased another seagate 2tb drive and was able to install the os the drive from disc 1 slot. So I have eliminated that the controller for the Duo has gone bad. I ha...
clblackman
thank you. that's how I got to learn that it might need an os reinstall
Damia
Nov 22, 2015Guide
make sure when you chose os reinstal to confirm choice by presing reset button briefly then os reinstal will start it dosnt take long in my case it took 5 min
- Jul 15, 2018Retired_Member
