dorian50's avatar
dorian50
ReadyNAS Duo v1 stuck on Booting after power outage
There was a power outage at my house which turned my ReadyNAS Duo off.  This has happened before so I manually powered it On but could not access FrontView or see it in RAIDar.  I then accessed the boot menu to power it On and Skip Volume Check.  Now, RAIDar can see it but stuck on Booting.  Still can't access FrontView.  Responds to pings from cmd prompt.
  • JennC's avatar
    JennC
    Jul 24, 2017
    Hello dorian50,
    OS resintall won't help. Is it configured as XRAID? If it is configured as mirror RAID, maybe try pulling out one of the disks and see if that will allow you to access the shares. The idea is finding out if one of the disks is causing the problem, so label the disks with which bay they are inserted and has been working, disk order is important.
    Welcome to the community!
    • dorian50's avatar
      dorian50
      Hi StephenB,
      Thank you for your reply.  Can the volume be lost if RIADar sees both disks as green/healthy?  Also, would an OS reinstall help in this scenario?
      • JennC's avatar
        JennC
        NETGEAR Employee Retired
        Hello dorian50,
ProSupport for Business
