Phenomenon_984
Jan 24, 2025Aspirant
Readynas duo v2 - network issue
I have pretty old ReadyNas duo v2 RAIDiator 5.3.13, which i would like to use as my backup. Everything went normal when i factory reset it, i can normally connect using default ip 192.168.168.168, pr...
Jan 24, 2025Guru - Experienced User
That is the failure address for DHCP. Was the NAS ever able to get a DHCP address from your router???
I tried to connect by ssh and telnet but both options are getting refused since it's not enabled on device, and i can't find where i could enable any of them via WebGUI
Telnet only works in tech support mode.
To enable ssh, you need to install an add-on. You can download it form here:
This is a "toggle" add-on. It has no ui. You remove it by installing it a second time.
Log into the NAS using root as the username and using the NAS admin password.
Phenomenon_984
Actually static address already was set at NAS before (it was local network) and after i remove it and let NAS get it from DHCP server i was stuck with this problem. So short answer is NO, never been able to get address from DHCP.
I have already downloaded and install add-on but didn't know it's "toggle" add-on as i was searching it under installed add-on, so you are saying i just need to install it and ssh will be enabled?
- StephenBJan 24, 2025Guru - Experienced User
Correct.
Is there anything unusual about your router setup? Are you using encrypted DHCP or do you perhaps have more than 2 DHCP servers set up in the router?
- Phenomenon_984Jan 25, 2025Aspirant
Thanks, i'll try installing add-on once again, and will try to set IP through ssh, hopefully i could enter with root access.
No, i don't have encrypted DHCP or 2 DHCP servers either.
- StephenBJan 25, 2025Guru - Experienced User
I should have said DNS on this, not DHCP.
