Ackis
Mar 19, 2014Aspirant
ReadyNAS Duo V2 - Not booting, can ping however
Not sure what happened (I'm at work) but my wife said the ReadyNAS Duo "stopped working". I RDPed home and I'm able to ping the system, it responds with a TTL of 64 but I cannot connect to it via w...
Ackis
StephenB wrote:
I would also try an OS reinstall first, which preserves data and most settings. The admin password is reset (to "password" on a duo v2), and the IP configuration reverts to DHCP.
OS Reinstall worked, much obliged.
