timip
Oct 22, 2015Aspirant
ReadyNAS Duo v2 / Hard disk capacity
Hello, I use a ReadyNAS Duo v2 with 2 hard disks 1,5Tb in X-raid2 and I would like to increase my storage capacity, what is the maximum capacity in x-raid2 for this equipment? Many thanks in advanc...
Oct 22, 2015Guru - Experienced User
What firmware are you running?
If 4.1.x, then you have a v1 (sparc cpu). Capacity is limited to 2 TB drives.
If 5.x.x, then you have a v2 (arm cpu). The HCL has disks up to 4 TB.
NAS purposed drives are good choices (WDC Reds or Seagate VN series).
timip
Oct 30, 2015Aspirant
Hi Stephen,
I have a 5.3.8 release, so if I understand your answer, I can mount 2x4Tb
Thank's a lot
Pascal
