cbiggins
Feb 25, 2017Aspirant
Readynas Duo v2 3 flashes
Hi All, The last few days my ReadyNas has not been able to start up. All LED's flash 3 times followed by 2 x "1" LED flashes. I have tried the ReadyNas with individual drives but this mad...
mdgm-ntgr
Apr 11, 2017NETGEAR Employee Retired
Did you try booting up the NAS with just the good disk installed?
Were you using X-RAID?
cbiggins
Apr 26, 2017Aspirant
I tried booting using several combinations of both disks and individual disks.
The LED pattern is for 'no disks detected'. Which makes me think it's a ReadyNAS problem.
If I was to buy a new ReadyNas (either the same model or a brand new one) can I just pop my disks in and away we go?
- StephenBApr 26, 2017Guru - Experienced User
I'd recommend an RN212 as a good replacement for your duo. It is quite a bit faster, and of course more features. I also suggest new disks for the new NAS.
The v1s became end-of-life in 2011, so if you get the same model you'd end up with a used replacement at best.
Unfortunately you can't directly migrate. It is possible to temporarily mount the volume (read only) in a new NAS. But with the v1's that requires assistance from support ( https://kb.netgear.com/29876/ReadyNAS-Migrating-disks-from-RAIDiator-4-1-or-RAIDiator-5-3-to-ReadyNAS-OS-6?cid=wmt_netgear_organic )
Some customers have reported that Netgear wanted to charge for full data recovery though - even though they thought their volume was healthy.
Do you have any access to a windows PC? There is a freeware tool that can read disk-1, but it isn't available on the mac.
- StefanP01Sep 06, 2017Aspirant
Hello,
can you share this freeware tool for us Windows users? I have about the same problem: wanting to access the Data on the RND2000 v1 which has broken down. I use a new Win 10 machine and connected the Disk 1 of the NAS via the SATA interface.
- StephenBSep 06, 2017Guru - Experienced User
StefanP01 wrote:
Hello,
What freeware tool are you talking about?
- StefanP01Sep 24, 2017Aspirant
IN message 9 you talked about a freeware tool without mentioning which tool.
I found the freeware tool: r-linux and it works fine. Thanks.
