dieu
Aug 26, 2012Aspirant
Readynas duo V2 disapear after a while
Hi, I have just bought a brand new Readynas duo V2 and I encounter a weird problem. I was able to install it without any problem but I discovered that after a few minutes the Nas is no more visible ...
de_niro
Sep 03, 2012Guide
Hi Dieu:
I got your system logs by even,and I found some improper speed setting on your eth0 port
Aug 29 19:40:41 Readynas kernel: eth0: link up, half duplex, speed 100 Mbps
Aug 29 19:40:41 Readynas kernel: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Aug 29 19:41:00 Readynas syslogd 1.5.0#6: restart.
I'd advise you set fixed link speed on NIC of your Readynas box,or connect your Readynas to the PC directly then copy data again.all you need to do this is help you to determine where the problem come from.
