flavior
Aug 16, 2017Aspirant
ReadyNAS duo (v2) disk tray in Europe
Hello, I need to buy a new disk try part number is RND4TRAY1-10000S for a ReadyNas Duo (v2), but I cannot find any seller in Europe - has anyone a suggestion? Thanks.
- Aug 21, 2017
https://toptechbuy.com/products/netgear-spare-disk-tray-with-screws-for-readynas-nv-nv
Just Googled the part number. These folks have it and will ship internationally.
Good luck!
flavior
Aug 17, 2017Aspirant
Maybe I can buy the disk tray directly on-line from US and get it sent to Italy? Where? How much is the shipping cost?
Marty_M
Aug 17, 2017NETGEAR Employee Retired
Hello flavior,
I believe that may actually work given you have address in US you can send to and then send to your Europe address. As for he cost of the process I am afraid I do not have the answer for it.
Marty_M
NETGEAR Community Team
- flaviorAug 21, 2017Aspirant
I don't have US addresses, so your solution is not suitable for me.
- hmuessigAug 21, 2017Luminary
Good luck!
- flaviorAug 22, 2017Aspirant
thank you, I'll try it
