Unknown1
May 14, 2014Aspirant
ReadyNas Duo V2 Disk Upgrade 6TB
Hello together, my Nas has aktually one 3TB disc installed. Thisdisc is nearly full and i want to have a raid 1 to avoid loosing data because of a disc fail. So i was wondering if it's possible to...
Unknown1
May 17, 2014Aspirant
Here in Germany that discs are avaiable.
I'm still in warrenty, but I've also other discs (f.e. the at the moment installed 3TB Seagate avaiable.
So should there be a problemn, I change the disc. Should the system work fine after that, it's my problem. Otherwise it's a warrenty topic. So I think warrenty isn't a problem. But I'm afraid to buy that expansive discs and after that they don't work.
So I think I'll watch the prices (I think they will fall very fast the next time) and then perhaps I'll try it.
Thank you for your support.
Best regards.
Best regards.
