Unknown1
May 14, 2014Aspirant
ReadyNas Duo V2 Disk Upgrade 6TB
Hello together, my Nas has aktually one 3TB disc installed. Thisdisc is nearly full and i want to have a raid 1 to avoid loosing data because of a disc fail. So i was wondering if it's possible to...
vandermerwe
Jan 03, 2015Master
The situation is the same as it was when you first posted:
It is probable that the disks will work, but they aren't on the HCL so you have a warranty issue.
How are you planning to backup the data. Have you considered using the duo as a backup nas and buying a new readynas that does have 6 tb disks on the HCL?
