Unknown1
May 14, 2014Aspirant
ReadyNas Duo V2 Disk Upgrade 6TB
Hello together, my Nas has aktually one 3TB disc installed. Thisdisc is nearly full and i want to have a raid 1 to avoid loosing data because of a disc fail. So i was wondering if it's possible to...
Unknown1
Jan 29, 2015Aspirant
I want to use the two discs in a Raid 1, so the duo is my backup.
I want to avoid to buy a new nas. One point are the costs and the duo works fine, has a good performance and so on. So the only advantage from a new nas for me would be the supported discs.
So I think I should try and if it doesn't work I've to buy a new one...
Thank you.
Thank you.
