jswartho
Mar 13, 2016Aspirant
ReadyNAS Duo v2 failure to boot and connect to network
It seems my ReadyNAS Duo v2 is not able to complete the system startup or once it does, it does not maintain a network connection. I'm able to connect to the device temporarily using RAIDar and I se...
Mar 13, 2016Guru - Experienced User
What firmware are you running?
The next step I suggest is to delete the log files from the web ui during the brief period the NAS is running. Don't attempt to download them. If the symptoms get better, then the likely cause of the problem is a filling OS partition.
If you cannot access the web ui, then you might consider paid (per-incident) netgear support.
- jswarthoMar 13, 2016Aspirant
The best I can tell the firmware version is v4.1.4. What is the cost for per-incident support? What can I expect for assistance incremental to the use of the Netgear Community? Thank you.
- StephenBMar 13, 2016Guru - Experienced User
If you are running 4.1.x firmware then you have a duo v1, not a v2. The labels are confusing, check this post: http://www.rnasguide.com/2012/01/09/how-to-tell-whether-i-have-a-duo-v1-or-duo-v2-or-nv-v1-or-nv-v2/
The good news is that you can extract the data off the NAS even if it doesn't boot by connecting disk 1 to a windows PC and using the free linux reader utility: http://www.diskinternals.com/linux-reader/ A USB enclosure/adapter can be used for the PC connection (or you can use SATA of course).
Once the data is safe, then a factory reset/recovery is something you can easily do on your own. It's a bit time consuming, but straightforward.
NOTE: remove/replace the disk in the NAS with the NAS powered down.
Prices vary be geography/currency, but last I heard US prices were $75 per incident.
This is for a Netgear support engineer to access your system remotely and solve the problem - quite different from asking/receiving advice here. Per-incident support doesn't include data recovery from a failed volume - that requires a different contract, and is quite a bit more expensive. If you want to pursue it, you should use support.netgear.com and ask.
