SwedenStockholm
Mar 09, 2021Aspirant
ReadyNAS Duo v2 fast flashing backup LED
Hello to all experts, Newbie on this forum, I now find myself in a desperate position and need help. Having searched the forum, I have found two threads that I have been trying to use as solutio...
Mar 09, 2021Guru - Experienced User
SwedenStockholm wrote:
So, my first (1) question: Is it worthwhile to repair an old ReadyNAS Duo v2? … or will it be “cheaper” (in the long run) to find a new one?
The chassis can't be repaired. You can replace the power brick, but that's about it. Your problem could be the disks though. If you remove the disks and power up the NAS, what does RAIDar tell you? https://kb.netgear.com/20684/ReadyNAS-Downloads
Second (2) question: I may have an opportunity to buy a used RND2000 v1 or a RNDU2000, which one is better? I understand this will be “downgrade” from the v2 I have?
The RNDU2000 is much better than the RND2000 v1, and IMO is an upgrade over what you have now. One reason is that you can convert it to run the current OS 6 firmware.
When you purchase a used ReadyNAS, you should make sure it includes working trays. Ideally it would also include the original screws for the trays - though those can be purchased if you know the correct specs.
Third (3) question: Can I just plug the two disks into the above used RND machines?
No. The disks need to be reformatted in order to use them.
If you can connect one of the disks to a Windows PC, then you can use R-linux for Windows to offload the data. https://www.r-studio.com/free-linux-recovery/
You could directly migrate your disks to a used NV+ v2. But you'd need to be careful on the model identification - many sellers of used NAS don't really know what they are selling. The NV+ v2 says ReadyNAS NV+ v2 on the front panel. Some labels on the v1 NAS might say v2 or even v3 - so you need to ignore those labels.
I am thinking that you should invest in backup - RAID isn't enough to keep your data safe.
Fourth (4) question: If I get the above to work, I understand that there is a high risk that the used RND may break because it is old and used. So, once up and running, maybe I should eventually buy a new NAS.
When and if I have a new NAS, how do I transfer all the data to for example a ReadyNAS 212 RN21200? Can I do so without using my LAN? Or even better, can I skip the third step above and plug my old hard disks right into a new 212 – without erase?
You can't migrate your disks. You will need to transfer over your LAN. If the used NAS is running, you can set up backup job(s) on the new NAS that can transfer the data.
One option is to use the old NAS for backup. After transfering the data, you can reverse the direction of the backup jobs, and back up your files to the old NAS on a schedule (for instance daily).
Inventory of desktop ReadyNAS has been limited for a while now - so IMO you should look at other brands also. They have similar backup job features, and it is possible to transfer files between different vendor products.
- SwedenStockholmMar 09, 2021Aspirant
StephenB,
Many thanks for your super-fast reply! :smileyhappy:
Well, I have tried tried to boot with disks installed and boot with no disks - no difference! Does not work! :smileysad:
So, it must be the chassis.
Thanks for notifying me on the risk buying used stuff - made me think that maybe the R-linux suggestion will be better in the end.
I'll buy a SATA-USB and check that the disks work... then I assume I can offload the data (old hard-disk => PC => new NAS with new hard-disk over LAN) to a new NAS via my PC using this cable?
- StephenBMar 09, 2021Guru - Experienced User
Are you sure?
You won't be able to access the web ui w/o disks, because the OS is installed onto the disks. Also, there will still be blinking leds (telling you there are no disks). But you can ping the NAS if you can find the IP address in your router's device list, and RAIDar should be able to find it even if it's not in the router's device list.
If the data volume is still intact, R-linux will let you offload it. Personally I'd get a USB drive along with the SATA-USB, and off-load it locally. But you should be able to offload it directly to the new NAS. You might need to map the NAS network share to a drive letter.
Are you sure?You won't be able to access the web ui w/o disks, because the OS is installed onto the disks. Also, there will still be blinking leds (telling you there are no disks). But you can ping the NAS if you can find the IP address in your router's device list, and RAIDar should be able to find it even if it's not in the router's device list.
Nope! Both disks installed.
ping = Destination host unreachable.
raidar = RAIDAR did not find a NETGEAR-storage in the network.
The backup led is flashing fast.
The disk leds are not lit at all.
