kingsville3012
Sep 01, 2014Aspirant
Readynas Duo V2 issue - RAIDar constant blue light #23802186
Hi all,
hoping to get some guidance - although i have a very basic understanding of tech talk!
I have a readynas duo V2 hooked up to a TP Link modem and my samsung smart TV.
I have had the above up and running smoothly for 2 years, however late last week i noticed the connection really slowing down to the point where now i can no longer connect to my NAS through either the ip address in chrome or through the network drive that i mapped.
RAIDar still picks up the readynas, however on the left hand side is a constant blue light (not flashing). Info bar quotes "File system check, 100%"
I have tried OS-reinstall but to no avail...
I also have getflix set up, however this shouldnt be an issue i am led to believe (?!) it was all running smoothly for months like this.
any tips would be really great!
cheers
DV
cheers
DV
- mdgm-ntgrNETGEAR Employee RetiredHave you tried contacting support via the Email tab on the Contact Us page on support.netgear.com ?
Can you post your case number? - kingsville3012AspirantHi,
I hadn't, but now have - Number is 23802186
thanks in advance
