yaouank
Apr 22, 2018Aspirant
ReadyNAS Duo V2 No RAID, replace 1 drive
Hello, I have a ReadyNas Duo V2 for years. I have 2 harddrive in it (1TB + 2TB), there is no JBOD, redudancy, RAID or anything. What I see on the web page: ReadyNAS Duo v2 RAIDiator 5.3.13 RAID ...
Marc_V
May 01, 2018NETGEAR Employee Retired
Hello,
ReadyNAS Duo v2
RAIDiator 5.3.13
RAID Type: Flex-RAID
/c RAID 0 (Not-Redundant) 27.2GB Free Of 913.4 GB
/d RAID 0 (Not-Redundant) 40.8GB Free Of 1.8 TB
I have a new 4TB HardDrive.
What is the correct way to use it instead of my 1TB drive (/c) ? Do I have to plug the drive while the NAS is on or off ? Is there an admin page I should access to tell ReadyNAS that there is a new drive and how it should use it ? (RAID ? JBOD ? Just a second drive ?)
I tried to plug it while the NAS is off, the drive is not dectected.
I tried to plug it while the NAS is on, it seems that the NAS decide to use it to be a redundant copy of /d.
It don't want any redundancy, nor JBOD. I just want to have a storage capacity of 4TB and 2TB (instead of 1TB and 2TB today) as 2 differents drives
It would be nice if there is a way to do this without having to erase everything on my 2TB /d drive (I have no extra drive to backup it).
Data from the 1TB drive are backuped on an other drive, no need for a full procedure on "how the change 1TB to 4TB without a backup space" (kind of "replace 2TB by 4TB", "copy 1TB on 4TB", "replace 1TB by 2TB", "done")
Hi yaouank
Welcome to the Community!
It seems that the Duo V2 is not behaving correctly when you try to expand the volume. With Flex-RAID when you add/.expand a new disk it should create another volume with the same configuration as the other volume left. JBOD will create another JBOD, RAID 0 will have another RAID 0.
When you replaced the 1TB drive you mentioned that the 4TB drive was being configured as a redundant copy of /d so the behavior seems to be like X-RAID which is not the case on what you have posted.
Expanding Flex-RAID Volume
There's no option to destroying/deleting a volume on OS 5 unless you are comfortable with SSH there might be a way. So I would suggest doing a Factory Reset to get a fresh set of JBOD disks 4TB and 2TB just make sure you have full backup of your data.
Hope this helps!
Regards
May 01, 2018Guru - Experienced User
Marc_V wrote:
... There's no option to destroying/deleting a volume on OS 5...
This is the key point. Unlike other ReadyNAS, OS 5 just doesn't have the feature you need. So a factory reset is the way forward (painful though that is).
If you expect your storage needs to continue to grow, you might want to get a second 4 TB drive.
You could then go with the normal XRAID. That would give you about 1 TB of free space now, and the option of upgrading both drives later on to increase the volume size - without the pain of another factory reset.
Or you could stick with two volumes and 5 TB free space - perhaps enough storage to last through the life of the NAS.
FWIW, a setup with one volume per disk is generally called JBOD here.
