_Thumper_
Oct 22, 2014Aspirant
Readynas Duo v2 poor performance on SMB connection
Hi Everybody, when I connect to my ReadyNAS trought a SMB connection I always obtain only 10MB/s read and write (it depends on the disk: less space seems to upgrade performance :shock: ). The funn...
Oct 22, 2014Guru - Experienced User
30 MB/s is way more than you need to stream a 1080p movie btw. BluRay is limited to 54 mbits (7 MB/s). 1080p downloads are typically around 8-10 mbits. (2 MB/s). So even 10 MB/s is more than enough to stream 1080p. If you are seeing stuttering or rebuffering, than that is due to something else (media issues, or possibly packet loss) - not the raw connection throughput.
Can you confirm that the duo is negotiating a gigabit connection? 10 MB/s is usually what you see on fast ethernet (100 mbit)
Also, if Anti-virus is off, the RN104 should be delivering about 2x the read speed you are getting.
