_Thumper_
Oct 22, 2014Aspirant
Readynas Duo v2 poor performance on SMB connection
Hi Everybody, when I connect to my ReadyNAS trought a SMB connection I always obtain only 10MB/s read and write (it depends on the disk: less space seems to upgrade performance :shock: ). The funn...
Oct 23, 2014Guru - Experienced User
Great. I also recommend that you test using a direct connection between one of the Windows systems and the NAS (taking the switches out of the equation).
It would be good to rule in/out the equipment on the network path, and that is the best way to do it.
