_Thumper_
Oct 22, 2014Aspirant
Readynas Duo v2 poor performance on SMB connection
Hi Everybody, when I connect to my ReadyNAS trought a SMB connection I always obtain only 10MB/s read and write (it depends on the disk: less space seems to upgrade performance :shock: ). The funn...
_Thumper_
Oct 27, 2014Aspirant
Finally I had a WE to perform all test. First of all, Intel NAS do not work with 7 and 8 x64, so I had to stick with NAS Performance tester. I must honestly said that performance are the same with the 104 and Duo v2, with about 11,5MB/s using standard Windows share according to the software (11,5MB DUO vs 11,8MB 104). It seems that the same problem with the Duo affects even the 104 on Windows machine. This seems strange to me because with other DL/UL I made the 104 performed better, but I had to report what the software said.
On the other side, since my Ubuntu desktop sees both SMB and CIFS (Duo) and ATP (104) share, when I choose CIFS/ATP both NAS perform much better, around 30MB/s.
I still wonder why this huge difference between "standard" SMB and CIFS, which should be a sort fo SMB dialect.
I forgot to mention that I made I direct connection in each case. Both NAS use Seagate 4TB NAS HD and capacity is 20% for both.
