_Thumper_
Oct 22, 2014Aspirant
Readynas Duo v2 poor performance on SMB connection
Hi Everybody, when I connect to my ReadyNAS trought a SMB connection I always obtain only 10MB/s read and write (it depends on the disk: less space seems to upgrade performance :shock: ). The funn...
Oct 28, 2014Guru - Experienced User
The checksums have value even if the files can't be repaired, as they verify the files are intact. I had checksums enabled before, and the corresponding option now seems to be bit-rot.
mdgm wrote: I think you would need to be running a RAID level with some redundancy to benefit from bit-rot protection.
I think the built-in bit-rot repair depends on btrfs itself, not the underlying RAID - unless Netgear has added some specialized repair.
