_Thumper_
Oct 22, 2014Aspirant
Readynas Duo v2 poor performance on SMB connection
Hi Everybody, when I connect to my ReadyNAS trought a SMB connection I always obtain only 10MB/s read and write (it depends on the disk: less space seems to upgrade performance :shock: ). The funn...
Nov 05, 2014Guru - Experienced User
If you have a windows PC, perhaps try NasTester to benchmark the SMB performance (http://www.808.dk/?code-csharp-nas-performance)
Did you change anything in the network - particularly a switch or router? Is the connection ethernet or WiFi/powerline?
Many players use fast ethernet connections. If you have a gigabit network, then you often run see these symptoms if the switch/router nearest the player doesn't support ethernet flow control. what happens is that packets queue up in the switch (which is downspeeding the connection), and w/o flow control the packets might sometimes overflow the queue.
