_Thumper_
Oct 22, 2014Aspirant
Readynas Duo v2 poor performance on SMB connection
Hi Everybody, when I connect to my ReadyNAS trought a SMB connection I always obtain only 10MB/s read and write (it depends on the disk: less space seems to upgrade performance :shock: ). The funn...
mdgm-ntgr
Nov 11, 2014NETGEAR Employee Retired
I see you last did a factory reset on 5.3.2. If you still encounter performance issues it may be worth considering doing a backup, factory default (wipes all data, settings, everything) and restoring your data from backup. This would get you a clean setup on the latest firmware. Over time some changes such as some filesystem improvements require a factory reset on newer firmware to take advantage of. We do our best to achieve good results with units last factory reset on very old firmware.
I see that one of your disks is a WD Green disk with a huge Load Cycle Count
