_Thumper_
Oct 22, 2014Aspirant
Readynas Duo v2 poor performance on SMB connection
Hi Everybody, when I connect to my ReadyNAS trought a SMB connection I always obtain only 10MB/s read and write (it depends on the disk: less space seems to upgrade performance :shock: ). The funn...
Nutty667
Nov 11, 2014Aspirant
Yeah I think the last time I did a factory reset was when some firmware update broke the system when it was switched off with power timer active.
Not sure how viable a factory reset is atm, as I dont have enough storage to back everything up. I may invest in another NAS soon.
Yeah the WD green is the older of the two drives. My previous green died and I replaced it with a red. What does Load Cycle Count refer to, and is it bad that its high ? Theres no actual errors reported in the SMART data.
I will probably replace that green with another red very soon.
