Snoopyonline78
Dec 30, 2020Aspirant
Readynas duo v2 with st3000dm001
Dear community I have only I think a simple question since eight years I have got 2x 3 TB hard drives ST3000DM001-9YN166 in my nas. yesterday one gives error and so I want to change the disk with a ne...
- Jan 02, 2021
Snoopyonline78 wrote:
Dear all, thanks for your help. I decided for the Seagate ironwolf pro 4TB 7200rpm CMR.
Will it work?Yes.
Dec 30, 2020Guru - Experienced User
Dear community I have only I think a simple question since eight years I have got 2x 3 TB hard drives ST3000DM001-9YN166 in my nas. yesterday one gives error and so I want to change the disk with a new one but I read it in the community that there are problems between the old model of my drive and the new ST3000DM001. somebody knows if I can buy a new model of ST3000DM001 and my raid willwork and syncin properly?
Don't get a new Barracuda.
If you want a 7200 rpm model, you can go with the Exos (ST3000NM005) https://www.newegg.com/seagate-enterprise-capacity-3-5-st3000nm0005-3tb/p/1Z4-002P-00148
If you increase the size to 4 TB or more, you would have more enterprise-class drive options. You won't see any capacity growth immediately - you'd need to replace both drives to get that.
Other 3 TB options include the Seagate Ironwolf drive (ST3000VN007) and the Western Digital TB WD30EFRX (not the WD30EFAX). They aren't 7200 rpm, but they will work fine.
- Snoopyonline78Jan 01, 2021Aspirant
Thanks a lot StephenB!
i have some questions to your answer:
You: Don't get a new Barracuda.
Me: You mean, the new models are not affidable? or is the performance bad?
You: If you want a 7200 rpm model, you can go with the Exos (ST3000NM005) https://www.newegg.com/seagate-enterprise-capacity-3-5-st3000nm0005-3tb/p/1Z4-002P-00148
Me: Thanks, but this means, i have to change the second disk too, or will this be combatile and working in Mirror-Raid mode too?
My wish is to spend as little as possible and have a mirrored raid sistem again
- StephenBJan 01, 2021Guru - Experienced User
New 3 TB Barracuda drives are SMR drives, which are not well-suited to use in RAID arrays. So the performance will not be good.
You can continue to use the second Barracuda.
- SandsharkJan 01, 2021Sensei
The new Barracuda drives are SMR, which will cause serious performance issues in RAID. Probably a bit less on that generation of NAS without BTRFS, but still not recommended.
The drives do not have to match except in size or the new one can be bigger, though you get no immediate usable space increase. If the rotation speed doesn't match, the NAS might complain (OS6 units do, I don't know about OS5.x), but it should work just fine.
- Snoopyonline78Jan 01, 2021AspirantThanks, i’m a little confused.
Stephen told me, to buy WD red drives, but red drives are smr :/
Thanks to all
- Snoopyonline78Jan 02, 2021AspirantDear all, thanks for your help. I decided for the Seagate ironwolf pro 4TB 7200rpm CMR.
Will it work?
Kindly regads- StephenBJan 02, 2021Guru - Experienced User
Will it work?Yes.
- Snoopyonline78Jan 02, 2021AspirantThank you all!!!!
