Snoopyonline78
Dec 30, 2020Aspirant
Readynas duo v2 with st3000dm001
Dear community I have only I think a simple question since eight years I have got 2x 3 TB hard drives ST3000DM001-9YN166 in my nas. yesterday one gives error and so I want to change the disk with a ne...
- Jan 02, 2021
Snoopyonline78 wrote:
Dear all, thanks for your help. I decided for the Seagate ironwolf pro 4TB 7200rpm CMR.
Will it work?Yes.
Dec 30, 2020Guru - Experienced User
Dear community I have only I think a simple question since eight years I have got 2x 3 TB hard drives ST3000DM001-9YN166 in my nas. yesterday one gives error and so I want to change the disk with a new one but I read it in the community that there are problems between the old model of my drive and the new ST3000DM001. somebody knows if I can buy a new model of ST3000DM001 and my raid willwork and syncin properly?
Don't get a new Barracuda.
If you want a 7200 rpm model, you can go with the Exos (ST3000NM005) https://www.newegg.com/seagate-enterprise-capacity-3-5-st3000nm0005-3tb/p/1Z4-002P-00148
If you increase the size to 4 TB or more, you would have more enterprise-class drive options. You won't see any capacity growth immediately - you'd need to replace both drives to get that.
Other 3 TB options include the Seagate Ironwolf drive (ST3000VN007) and the Western Digital TB WD30EFRX (not the WD30EFAX). They aren't 7200 rpm, but they will work fine.
Snoopyonline78
Jan 02, 2021Aspirant
Will it work?
Kindly regads
Will it work?
Kindly regads
