xcube
Aug 26, 2012Aspirant
ReadyNas Duo v2 wont power up (5.3.5)
Hello, I believe that I have found a bug with the latest Radiator 5.3.5, my ReadyNAS Duo 2 wasn't able to power up after I did the following: 1) Go to Settings> Power 2) Enable Power Timer 3...
mdgm-ntgr
Aug 26, 2012NETGEAR Employee Retired
Sounds like you've run into a known issue you may still have the old u-boot. Please check the u-boot version (See Duo/NV+ v2 – important u-boot update if using power timer) and if you have an old u-boot, download 5.3.5 (http://www.readynas.com/RAIDiator_arm_5_3_5_Notes) and do a local update installing it over the top of itself. The u-boot should then be updated.
Welcome to the forum!
