xcube
Aug 26, 2012Aspirant
ReadyNas Duo v2 wont power up (5.3.5)
Hello, I believe that I have found a bug with the latest Radiator 5.3.5, my ReadyNAS Duo 2 wasn't able to power up after I did the following: 1) Go to Settings> Power 2) Enable Power Timer 3...
xcube
Aug 29, 2012Aspirant
I am not sure whats happening to my ReadyNas Duo2. But, it stop detecting my volume after I did a shutdown with the scan boot enabled.
It was showing the drive information but it couldn't load volume (c). I tried reinstalling fw 5.3.5 but it still seems to have the same issue. After the upgrade I check Rairar and the status says (even after 24hrs after the update):
Blue bubble (Background task active) and in info: File system check, 100%.
This HDD is a 2tb HDD with only 90gb of free space.
Is there something wrong with the NAS? The HDD was working fine before, and I had the same problem with another HDD of 1tb. I didn't had any problems before.
