xcube
Aug 26, 2012Aspirant
ReadyNas Duo v2 wont power up (5.3.5)
Hello, I believe that I have found a bug with the latest Radiator 5.3.5, my ReadyNAS Duo 2 wasn't able to power up after I did the following: 1) Go to Settings> Power 2) Enable Power Timer 3...
mdgm-ntgr
Aug 29, 2012NETGEAR Employee Retired
This is quite a different issue to the one you described in the first post. With the power timer disabled having the old u-boot wouldn't be a problem. Contact NetGear tech support and post your case number.
